The approach I would follow, in addition to all the other great suggestions above, is to obtain (from the vendor) the spectral output of the proposed LED.
As others will have correctly noted, the amount of UV A emitted by the LED will be a minute fraction of total light output. For UV B (the real concern) with its shorter wavelength, the total emission may be negligible.
In any case, I suspect that LEDs with blue-tinted lenses will absorb the vast majority of spurious UV emissions. Think of it as a low pass filter.
