Jester
Full Member level 6
I have a request to develop a simple PCB that will be a customized version of an off the shelf Arduino pro-mini board.
The original pro-mini board uses a 32pin ATMEGA328, however the customized board is to use the 28 pin variety of the ATMEGA328, so the pin-out is slightly different.
The software developer is using Arduino Sketch to load code into the pro-mini development board and would prefer to continue using this tool.
I downloaded a copy of "Sketch" and there are selections for the various Arduino boards, however there does not appear to be a selection for specific varieties of the ATMEGA328.
So does this rule out using "Sketch" to develop and download code to the new board that will use the 28 pin device instead of the 32 pin device that is used on the pro-mini board, or is there a way to get sketch to use the pin-out of the 28 pin device?
