[SOLVED] Arduino SD card help
wizpic
Advanced Member level 3
London
I've decided to take the plunge and switch to the Arduino after using PDS for many years, I want to build a data logger but stuck on a little problem
I've got this test code working and every time the arduino starts it creates a new file and logs every five seconds.
#include <SPI.h>
#include <SD.h>
//Set by default for the SD Card Library
//MOSI = Pin 11
//MISO = Pin 12
//SCLK = PIN 13
//We always need to set the CS Pin
int CS_pin = 10;
int pow_pin = 8;
char filename[16];
int n = 0;
float refresh_rate = 0.0;
void setup()
  Serial.begin(9600);  // Open serial communications and wait for port to open:
  Serial.print("Initializing SD card...");
  pinMode(CS_pin, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(CS_pin)) {
    Serial.println("Card failed, or not present");
    return;
  Serial.println("card initialized.");
  //char filename[16]; // make it long enough to hold your longest file name, plus a null terminator
  snprintf(filename, sizeof(filename), "data%03d.txt", n); // includes a three-digit sequence number in the file name
  while (SD.exists(filename)) {
    n++;
  File dataFile = SD.open(filename, FILE_READ);
  Serial.println(n);
  Serial.println(filename);
  //now filename[] contains the name of a file that doesn't exist
  //Write Log File Header
  //Read the Configuration information (COMMANDS.txt)
  File commandFile = SD.open("COMMANDS.txt");
  if (commandFile)
    Serial.println("Reading Command File");
    float decade = pow(10, (commandFile.available() - 1));
    while (commandFile.available())
      float temp = (commandFile.read() - '0');
      refresh_rate = temp * decade + refresh_rate;
      decade = decade / 10;
    Serial.print("Refresh Rate = ");
    Serial.print(refresh_rate);
    Serial.println("ms");
  else
    Serial.println("Could not read command file.");
    return;
void loop()
  File dataFile = SD.open(filename, FILE_WRITE);
  if (dataFile) {
    int sensorValue = analogRead(A0);
    float voltage = sensorValue * (5.0 / 1023.0);
    Serial.println(voltage);
    dataFile.println("teste");
    dataFile.println(voltage);
    dataFile.close();
  else {
    Serial.println("error");
  delay(refresh_rate);
But I want to be able to add an header but get stuck it will not compile I get an error this is the code I'm trying to add the header as I only need it once at the top of the file
#include <SPI.h>
#include <SD.h>
//MOSI = Pin 11
//MISO = Pin 12
//SCLK = PIN 13
int CS_pin = 10;
int pow_pin = 8;
char filename[16];
int n = 0;
void setup()
    return;
    n++;
  Serial.println(n);
  File dataFile = SD.open("LOG.csv", FILE_WRITE);
  if (dataFile)
    dataFile.println(", , , ,"); //Just a leading blank line, incase there was previous data
    String header = "ID, Light, Temp, IR1, IR2";
    dataFile.println(header);
    dataFile.close();
    Serial.println(header);
  else
    Serial.println("Couldn't open file");
  if (commandFile)
  else
    return;
void loop()
  if (dataFile) {
    dataFile.close();
  else {
The error I get is
sd_read_write.ino: In function 'void setup()':
sd_read_write:38: error: redeclaration of 'File dataFile'
sd_read_write:32: error: 'File dataFile' previously declared here
How can I add header bearing in mind I'm new to this and still learning
Thanks
you are defining twice dataFile and any compiler would not like that...
the first "File dataFile" is ok, now change that single line to:
now you are reusing dataFile and i think it should compile at least. (but maybe the library doesn't like to reuse things so keep that in mind)
Reactions: wizpic
    wizpic
Has simple as that, it complies ok quickly tried it and it looks like it's working but second time only bit wrote to file header but will do more testing as its late and brain is not fully awake
Thanks for helping
Kurenai_ryu thanks for that, I for some unknown reason I deleted the extra bits of data from that line all working now.
