[SOLVED] arbitration issues in can communication
debabrta kar
Member level 5
Member level 5
india
i am doing can communication using at89s8252 mcu, mcp2515 can controller, pca82c250 can tranciever..i have doubt that if on a can bus if two data frames with same identifier and same data field will arise at the same time ...then will be their any arbitration occured and if yes then who will win and who will loose the arbitration...please guide me thank you
I think as per bus arbitration is simple AND operation. So it will send both frame and both frame will the arbitration. and if it losses bus arbitration then it will send the frame again.
so who will loose arbitration and how....because as i said that both the frame having same bits upto the data field means the identifier and datas are same how the arbitration occures please explain it sir..........
CAN controllers monitor the bus lines while they are transmitting (listen while talking). As soon as they detect a dominant bit (usually low) when they are trying to send a recessive bit (usually high) as sampled at the configured bit times, it will assume that someone else has the bus and it will stop transmitting, and will back off for a preconfigured random time interval before re-trying any transmission. So, normally if you do want to give a slight priority over a particular device on the bus, you give it an address with the most dominant (low) bits to use on the bus - it will tend to win any bus arbitration issues the soonest.
dear ftsolution , sir actually i asked that if two node are with same identifier that is the address of device as u said and the data field are same that means two identical data frames ...it means they have equal number of dominant and recessive bits then how the arbitration will occurre and who will win the arbitration and how....
as i said earlier that bus is AND logic that is if one node send dominant and other one is sending recessive then dominant bit will the arbitration and will on bus.
In your case both frames are same that is ID and Data also then all the bits will the same.
If both frame starts tx at the same time then both will on bus till complete tx.
and If same frame sending at different time it follow the arbitration rule and node will the win as per arbitration.
how it is possible that two data frames will be on bus till complete tx.....that means if two nodes are trying to access one same node by sending their data frames (both the data frames are identical as i said above) ..then the 3rd node will receive both the frames ...how is it possible ...please explain because as we know on a can bus at a time only one frame can be avalible and only on bus can access the bus at a time ...otherwise it will violate the arbitration rule...please explain your point sir.....
You are postulating a quite unlikely situation except by intentional mis-use/experimentation of the CAN bus. In general, (2) nodes won't be EXACTLY synchronized and even if they differ in timing by some reasonable fraction of a bit width, one or the other (the first to start with a dominant bit) will win, based on the sample points within the bit widths. If you did intentionally, exactly, synchronize (2) nodes with the exact same message and sent them at exactly the same time, there would in essence, only be (1) message on the bus (the exact same one) even through it came from (2) sources. There are times when we do want to send a broadcast message out for all (or many) nodes on a CAN bus to receive at the same time, but on the same bus, we generally want the messages to be identifiable as to their source - this is commonly used with the producer-consumer model.
In this model, it is common for a producer (message sender) to issue a message that will be simultaneously received and used by multiple consumers. If you have multiple producers which are producing the exact same message at the exact same time, there is no advantage/use to it. The consumer nodes cannot tell the difference. The principle advantage of CAN is that a single message can be received/used by multiple nodes at the same time, contributing to the efficiency of the system.
