AkhilKalathungal
Newbie level 3
This requirement is for my Masters Thesis project. My professor would like to see the implementation of arbitrary precision
integer arithmetic on Altera FPGA DE-2 board. The HDL used should be Verilog. One way to implement is, to modify
the NIOS ii processor architecture (which has 32 bit registers) by adding custom instructions. So, if there is a need for 1024 bit
variable support, we can have data-chunks of size 32 bits * 32 numbers to construct those 1024 bits.
(Please do not ask me to create a reg of 0:1023 or bit 0:1023 in Verilog, we would like if the synthesized core can go and fit into the hardware properly, hence need this arbitrary precision logic to be implemented somehow).
Since I am a beginner in Verilog, one question I have is there a possiblity of linked list type of implementation in Verilog?
If the above requirement was in C, we would have used a linked list structure with the first 32 bits pointing to the address of the next 32 bits, and so on. I was wondering how to implement the same in Verilog.
Please advice me here and any small hints will be really appreciated.
Thank You,
Akhil
Thank You,
Akhil
