pedalpower
Junior Member level 1
Hello to everyone.
I have a Apogee Duet Firewire. It developped wierd issue. All lights exept two on channel 2 are on when connected to Macbook pro. Duet doesn't recognized by Mac. Contacted Apogee they suggested to replace TSB41AB1 IC chip. I replaced it with no difference, still the same problem. Contacted Apogee for shematics, but they refuse to give it up, even the unit was discontinued and not supported by the company. I started to figuir out myself what might be wrong. Ane what I found was: it has another IC next to TSB41AB1, OXFW971-TQAG and when I heat it up with the solder the unit start normally and work with no issues even if I live it on and working for 24 hours. Or I can pluge the unit on, all lights are Up, leave it for 7- 10 menutes then reconnect and it started normaly. I thought the problem is that IC cheap. I replaced it with Brand New one but no luck. I purchased secon Brand new one still no luck. Measurred all voltages on another working Duet and they are different. Soldered back original one heat it up and it works. My question what might be wrong, now I don't think it is a IC. Any Help would be appreciated. If any one has a Schematics of a Duet will be hellpfut also.
Thanks.
Thanks.
