StoppTidigare
Full Member level 2
- Joined
- Jul 16, 2002
- Messages
- 148
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Northern earth
- Activity points
- 1,703
bfg425w.s2p
Hi all, I need some help from Aplac-lovers to finishing up an old lab I've left behind me years ago.
The goal is to design a narrowband 10Ghz amp using
Philips BFG425W Npn transistor.
It should be designed for maximum gain, and less than -10dB input and output reflection coefficients.
I know how to do it in theory, because I've read the Gonzales book so many times, but I've forgot my Aplac knowledge. And this is the tool one is expected to use...
I need to extract from the example-files the S-parameters at 10Ghz, given by the teacher and which I attached to this message.
I want to edit the file so that I get the S-parameters for the bias-condition
that gives the highest transconductance gm.
That is I also need to find out which bias-currents Ib and Ic gives me that...
Could some kind soul help me with that ? I remember that one could add a text-object and write a PRINT -statement, but one has be careful not adding too many spaces or something in the syntax. I remember it was horrible !
I also have questions about the coupling capacitors in the bias circuit, these are by the teacher set to 1 Farad !!! Is it becuase the scope is to get
the "intrinsic" S-parameters of the transistor, that is that we want no interference at this stage from the world outside the transistor itself.
I am fully aware of that the coupling capacitors in the final circuit will be a part of the input and output matching circuits, and there values will be determined by the input and output matching networks. And since the frequency is so high I can use small valued capacitances and still have consider it as short circuit for ac.
I know how to do the rest, stability-,operating power gain-,availible power gain -circles.
Hoping for some help...
Kindest regards,
StoppTidigare
Kindest regards,
StoppTidigare
