Anyone konw this circuit in the attachment?
icsoul
Member level 3
Member level 3
What kink of circuit it is ?
How to analysis its transfer function?
I want to get some stuff for this circuit.
Thanks !~
Taking into account first order effects only the transfer function is
v(outn)/v(inp)=Gm*Routn, v(outp)/v(inp=Gm*Routp, here Gm=(1+sRC)/R
A similar circuit is commonly used to remove the long tail in gaseous detectors for high energy particles. It's called a shaper there, or tail cancellation amplifier.
There's a description of such a circuit in here ,
http://dx.doi.org/10.1016/j.nima.2006.02.168
and the concept is explained here
a chip implementing this appears here,
look for the shaper section.
hope this helps.
used to extend bandwidth of gm
Alex_IC:
Could you explain how to get this transfer function?
Added after 5 minutes:
hope this helps.
I can not access the first URL.
This circuit is used to compensate high frequency loss.
Now I want to know is that what's the operation principle, how to analysis, and what's the type(name) of this circuit?
Whatever, thank you very much!~
hi, hunk
Could you explain this in more detail?
Thanks!~
We can assume that gm>>1/(2*R), so that at low freq (where Cap is negligible) the effective transcondactance of the DiffAmp is Gm=1/R. At high freq the Cap shunts the R, and effective transcondactance is Gm=1/(gm+gm).
So more accurate eqation is
v(out)/v(inp)=(Rout/R)*[(1+RCs)/(1+gmCs)]
    icsoul
Thank you, Alex_IC!
It is very helpful!~
This circuit is called amplify with high freauency boost.
This circuit also has the advantage of degenration without an IR drop and having more headroom. The disadvantage is that it has higher noise due to current sources noises which are not common so the noise is uncorrelated at the Gm's output. The circuit is used to have broadband amplification where at high frequency the capacitive load dominates the output impedance and so the Gm will get higher to have the same gain.
Hi,cdz
Do you have some good stuff about this?
Added after 2 minutes:
Hi, Jim cage
Could you recommend some material about this topic?
