vivimz said:Hi, Is there anyone who has some experience about the slew rate detect circuit? Pls share with me some design idea. Thanks a lot!
vivimz said:hi, the slew rate here is the rising and falling slope of the high speed signal.
vivimz said:The signal speed is around 2Gbps. Basically we want to detect the signal rising slope, if the signal rising slope is too slow we want to make it faster.
Thanks for your reply
dfullmer said:Hi,
Could you ac couple the edge signal and rectify it into a dc level. The sharper the edge (faster slew rate) the higher the ac couple and the more dc level? I don't know how fine a slew rate range your working on but if it is a gross error this could work.
dfullmer
rfsystem said:Solution:
Couple signal via a small cap (50fF) to a current summing node. If the cap current compensate the bias current also injected into this node the current sum change sign. That is used as digital signal. Two comparators define the 10%/90% transition region. To adapt to this huge slew rate range use different current settings. I think you want to built a an autoconfiguration serial interface?
vivimz said:dfullmer said:Hi,
dfullmer
Hi dfullmer, thanks. I am trying to use this way currently.
And is not working, of course.
Added after 8 minutes:
Please tell him also how fast must be the comparators and the fact he must know where is with the slew rate at least approximatively.
Almost forget, please explain him how will built the 50fF capacitor using just the PCB and how must be isolated the node against leackages...
