Anyone is using Liberty Parser?
eruisi
Member level 4
Member level 4
CA
I am using Liberty Parser 2.5 from Synopsys to parse and process liberty files.
There is a Perl interface in the package so I use it to make my programming easy.
However, I found one issue in in this Perl interface: it's good to read .lib but when it comes to write out a modified liberty to a file using liberty::si2drWriteLibertyFile, it re-formats a lot to original liberty file: it re-factories tab indents and add double quotes to many string values
for example, original liberty has syntax like
cell(AOI), not it becomes cell("AOI")
This is not a fatal error, but it make visual check or text diff very difficult.
Does anyone use Perl Liberty Parser too and ran into the same issue? Is there a way to minimize the re-formatting from Perl interface.
What I found is C API won't change much on format and for Perl interface, if I don't modify data (add/delete cell/pin/attribute) and write a liberty, then there is no re-formatting, but if I change some thing then write out liberty, it will add a lot of double quotes ("")
Any help is much appreciated.
Thanks
I am not familiar with any of those tools, but it sounds as though the program 'remembers' that the file started as a Liberty document. So it insists on processing it as a Liberty doc.
What if you were to start it as a generic document? Then it might process it as 'generic'.
1) Copy the entire file to clipboard.
2) Start a New document.
3) Paste in the clipboard contents.
This should remove all hints that it is a Liberty doc.
This is not I was talking about, but thanks anyway.
