anyone has schematic of automatic voltage regulator (AVR)
nash10
Junior Member level 1
Cavite - Dasmarinas
automatic voltage regulator schematic
thanks in advance..
auto voltage regulator schematic
I'd like to repair my defective avr here,and I need schematic..
thanks for reply..
automatic voltage regulator avr
hi dear,
kindly always give the complete information like model no and power spe of your AVR
avr voltage regulator
Are you refering to the automatic voltage regulator (AVR) used in diesel generators? or the regular DC regulators mentioned by "hanif" in his post above?
Re: anyone has schematic of automatic voltage regulator (AVR
I need avr for generator set with 100kva capacity, anyone can help me ???
Thank for advice,,
100kva, is it for a home or for a small village? Hahahahah.
Hi All,
I also looking for a AVR schematic to repair my defective unit here.
This is use for my PC.
The model is AVR F1000, i can see a model name inside the board stated AVR8810.
TheRating is 1kVA.
Anyone has schematic for this model?
I can see there are inverting amplifier used in the circuit which I believe is quite similar with the application from "Hanif" link.
But not really sure is this the the purpose or not.
Can anyone advice?
Thank you
Please check out this 10KVA automatic voltage stabilizer circuit designed using SSRs by me:
How to Make a 5KVA to 10KVA Automatic Voltage Stabilizer Circuit Using Solid State Relays
Thanks,
Swagatam.
Mod: Promoting link removed. The op is asking for automatic voltage regulator used in generators and not Stabiliser. Next time is see your blog promoting link for non related topics, take this as a pre- warning..
