I guess beabroad is referring to burst-mode CDR in optical communication systems, which is recently inspired by the high demand of GPON transceivers in Asia (Japan and China).
Up to date, I don't get a good design reference in this type CDR. Actually you will find the reference for burst-mode driver/TIA is also very limited. Real markets are pretty much dominated by one or two players in the field. Plus not standard has been adopted for GPON transceiver yet as far as driver/tia concerned. I see alot different ways to use these parts -- which absolutely would influence the CDR performance too. Just keep in mind: current design at 1.25G burst-mode ckts are very much like the old 155M parts; however, I have to admit some technical issume must be well addressed before we can follow the old approach, like the high-speed peak-detector.
Personally, I consider for burst-mode CDR the conventional binary PD are more robust and suitable. It's worth a good investigation! Keep us posted of your progress. Good luck.
