Any paper about the monitor circuit of power switch current?
xiexi
Member level 4
Member level 4
There can be a small resistor to convert the current to voltage, but I think there must be a better circuit than that, can anyone give me instruction, thank you.
Re: Any paper about the monitor circuit of power switch curr
hi,
try MAXIM chips....
like MAX4080.......
depends upon your current u can use Rsense value....150mR or 100mR.....(2512FP)
usually it is hard to find the required sense resistor....to use them either in parallel or series.....
u can get good resistor from Phycomp
pls do not forget to use help me button
    xiexi
But what I need is the circuit different from using resisitor, and I have pushed help me button for your warm-hearted.
is this good idea for you to use...
OPAMP based I to V convertor.....
or you are looking for something else.... ??
