Any one help to solve the issue in schematic ORCAD
dsanthosh67
Member level 4
Member level 4
INDIA
Hi all,
After completing the design when i check DRC am getting this error what could be the problem,Actually using two part of that ic only U1A and U1B
ERROR: [DRC0026] This reference has already been assigned to a different package type. U1
SCHEMATIC1, PAGE1 (4.60, 9.10)
https://obrazki.elektroda.pl/9020804300_1406638295.jpg
You need to group the two sections of the part together. What I've done in the past is create a new property (select the two sections, and RMB/Edit properties). Create a New Column and call it, say, PKG_GRP. Then assign the same value to both sections. When you go to Annotate, add the property you just created to the Physical Packaging Combined Property String.
