Any Idea on Making Transistor or Atleast a Diode at Home ?
my_books
Full Member level 5
homemade transistor
Thanks
make transistor with diodes
a_tek7 said:
I think IT's Impossible
You're too young...read and listen !
    my_books
make diode from transistor
YES.I have n0thing to say
homemade flame triode
not possible really
transistor making
check this out
steps of making transistor
It is possible but the way you can do it depends on staffs that you have available and your experience. I'm also very interested in rough science, may I ask why you want to do this? anyway you can build a triode if you can create good vacuum, Some links below may give you some idea:
This guy has some experiences
read home evacuated vacuum tube.
Also this is interesting
http://www.sparkbangbuzz.com/flame-amp/flameamp.htm
regards,
making transistor with diodes
Assuming this is just for fun, get hold of an old SRAM , DRAM or microprocessor chip - older the better because the silicon chip will be large.
Mill off the top of the plastic of the IC until you expose the chip and the Gold wires bonded to the chip. Remove the wires. The silicon chip is most likely a thick P-type Si, with <5 micons of "stuff" on top. Using diamond grit, polish off the "stuff" on top until the chip looks shiney.
Remove the chip from the rest of the package preserving the coppoer back contact to the chip.
Switch to colloidal silicon (really fine) polishing for making telescope mirrors and buff the exposed original top surface using as fine a felt cloth as you can. If possible use de-ionised water with the silica particles.
Now to make the worst possible schottky diode in the world, apply silver paint to the top surface and bake it using a quartz halogen bulb at max power.
You now have the worlds worst schottky diode that will leak like a Government secret, but think of the brownie points.......
5 ways of making a diode from transistor
Or perhaps u can put ur energies to something useful
Re: Any Idea on Making Transistor or Atleast a Diode at Home
My_Books and all,
Articles and discussion on homemade transistors and related projects can be found at
http://groups.yahoo.com/group/home_transistor/
Photos and diagrams of my homemade transistors can be found in the photos and files sections at
Happy experimenting,
Mikey Faraday
