any help regarding RTLinux programming
dev
Junior Member level 3
Can anyone help me with some thing about RTLinux.I'm heading for RTLinux as a beginer with linux :roll:
c´mon...how about googling for "rtlinux howto" ?
Returns shitloads of links... (o;
And why you want to start with rtlinux if you´re not familiar with linux itself? RTLinux is just a set of patches to include sort of realtime capabilities to the irq handler...
There are many variants of RT implementation available for Linux, all with different advantages, do a little research and choose whichever suits your purpose.
Check these links for more info on RT Linux.
http://www.mvista.com/dswp/realtime.pdf
RT Linux is nothing but Linux with real time flavour so it will be better u take the basics of real time and start working on that and If u will ask any perticular question then it will be easy to reply...
Here you can find some tutorials, examples and a comparison between RTLinux and RTAI. (Some documents in spanish)
hxxp://rtportal.upv.es/
If you do not know Linux well do not jump to RTlinux
there is a saying way to the top is only through ladder of hard work but pleas climb the ladder 1 step at a time else you may have a nasty fall
good luck
Added after 42 seconds:
good luck
