any difference between op amp and differential amp?
The operational amplifier is a circuit with a high open loop gain, High input resistance and low output resistance...
There are op-amps with:
Differential input and single output
Single input and differential output
Differential input and differential output
Single input and single output
Many opamps have a diffential amplifier in theirs input circuit followed for a high gain circuit and in their output is a amplifier B class (op-amp 741)
I hope this can help you...sorry if you can't understand well this post but i dont write in english very well
    leohart
Hi
Do you mean Ideal opamp?
opamp output resistance is low but most of diff amps has high output resistance.
regards
    leohart
OP amp includes one or more differential amplifiers. Normal OP amp has typically more than 4 stages so as to have the characteristics of the OP amp. The first two stages are typically differential amplifiers.
    leohart
