antenna with a branch line coupler
sahar20
Member level 1
Member level 1
branchline coupler
I m modeling an antenna with a branch line coupler connected to it.Using Mgrid Layout. Feed is given to one port of the coupler. How I can give 50 Ohm termination to the other port of the coupler ?
You can define a port there. Then, you can terminate to 50-ohms or whatever termination you want on MODUA or MGRID in visualizating the current and doing the pattern calculation.
    sahar20
