radioCanada
Newbie level 6
Hi all,
You might all have read the chapters on antenna
transmitting and receiving reciprocity, almost always
explained via an easy dipole or horn antenna.
Most of antennas are not that easy and especially
Antenna Arrays with complex feeding networks will
require - at my opinion - more considerations in order
to declare reciprocity.
For example:
If a feed network is corporate (parallel) and each branch
of the feeding network is completely asymetric, let s say composed
by dividers, the antenna will NOT receive the same amount of RX
energy, right ?
But at the same time, some of the energy will be back scattered
(due to no good S22 of the feed network) and appears back at
the antenna array elements.
NOW HERE is my problem to understand: Am I right that this energy
will at least change the near field solution of the antenna?
Or will it even have an influence on the radiation pattern in RX itself?
Think about other configurations: Leaky Wave Antennas, Traveling Wave
Antennas (Wire, Slot,..).
Give me some new ideas how to solve my problem and I am glad
to give you support , too!
RadioCC
For example:
energy, right ?
RadioCC
