rubdawg
Member level 1
I was measuring at the feed point on a printed circuit board antenna and the impedance was supposed to be seeing about 200 ohms for 2.4GHz application. But when I measured it was about 20 ohms (this is from a previous engineer here). I am new to antenna and when I measured the antenna without the feed point, it measures about 180 ohms but as stated above, the with the feed point it is 20 ohms, any insight??
