beni_annis
Junior Member level 2
Hallo Every,
I am designing coil antenna on PET substrate using cst microwave in the frequency domain but I am having always problem in the port description. Could anyone tell me which port is suitible for the my structure " I am using now discrete port sparameter port" knowing that the dimensions of the coil are:
square shape 30 mm* 30mm , the space between the lines is 1 mm, the width of the line is also 1 mm. I attached the picture of the my problem please if any one can help me I will appreciate that. thanks for your help in advance :-D:roll:
the frequwncy range is from 125 khz to 30 mhz.
