[SOLVED] Antenna Calculation for Standard Cells
eklikeroomys
Full Member level 3
Full Member level 3
South Africa
Halo,
I am using Cadence Abstract Generator to create abstract cells for a digital standard cell library. The Abstract Generator user guide states that Antenna Calculations are switched off by default for standard cells. Does this mean that antenna calculations are unnecessary for standard cells?
I am confused by this.
Thank you!:roll:
For anyone wondering about the same thing, I found the solution. Since standard cells are relatively small, signal conductors are probably very small as well, and antenna calculations are not necessary for individual standard cells.
