antenna array on 60GHz
jayleung
Member level 5
Member level 5
60 ghz antenna
Hi, everyone. Has anyone designed the 60GHz antenna array before? I have some questions about it:
1) which types of the antenna will be suitable for such a high frequency, microstrip patch antenna, slot antenna, printed dipole antenna or something else?
2) which fabrication techniques should be used, PCB, Ceramic, or silicon microelectronics? What are their pros and cons.
Thanks.
dipole antenna 60ghz
Hi
I think Patch antenna array is useful.
See the paper on link below .
This will help you to understand.
Abhishekabs
    jayleung
60 ghz patch antenna + pcb
But I cannot open this link. What is the name of this paper? Thank you very much!
Added after 1 minutes:
And any other materials about such array available?
i think patch antennas aren't useful in this case since their losses increas as you increase frequncy, i think reflector antennas are suitable
collin antenna book is helpful
regards
i also think patch would be best for it.
azam
Reactions: kutyba
    kutyba
Thanks.
u can use spiral array.......its use for high frequency
Reactions: kutyba
    kutyba
