Ansys HSFF simulation error while designing the probe patch antenna
rohitpintusurya
Newbie level 3
Newbie level 3
hi,
As I am a beginner and this is my first design(probe patch antenna) in Ansys HFSS simulator, I am facing a problem i.e an error(warning is created will "checking all" . the error is in "boundary and excitation" part (to surfaces are overlapping ) .
I am attaching a rar file(probepatch.rar) which contains the design and result part .
help me guys .
Thank you :)
  • probepatch.rar
Welcome rohitpintusurya,
While I only have HFSS 13, it appears that you've assigned the radiation boundary to all sides of your vacuum box - including the bottom face to which you've also applied a PEC boundary. You can't have both applied simultaneously - delete the radiation boundary. Select all faces of the vacuum box except for the bottom face, the apply the radiation boundary. Also, your PerfE_patch PEC boundary should NOT have "infinite ground plane" checked.
Also, for future reference, you do not need to attach the .results folder - it will usually be very large, and is not needed to transfer the design. Just the .hfss file is needed.
Good Luck
PlanarMetameterials
Thank you very much for your support PlanarMetameterials.
I will implement those changes to it .
