arwen16
Member level 1
Hello,
We designed a class AB PA using CG2H40010F (VGS=-2.4V, ID=250mA) on Rogers 5880 (Er=2.2). We did the S-parameters measurement and they were in good agreement with the simulation. We did notice post measurement that our board was slightly warmer (we did use a heat sink of 40x60mm dimension). We waited for it to cool down before moving to the power measurements. We used a SG, a preamp, a 60dB attenuator and an SA to measure the power output. On connecting the PA in the setup, there was a sudden spike in drain current (~1A). We quickly turned it off and disconnected the preamp from the i/p and the attenuator at the o/p. We checked the DC and it was stable. When we tried reconnecting to the preamp, there was a spike in current again. We then removed the preamp and decided to just connect the input of the PA to the SG with RF off. We encountered the same issue. We did notice there is a small gap between the board and the heat sink even after applying thermal paste.
We are fairly new to designing PA and are still understanding the practical implementation of one. Kindly help.
