giorgos3924
Junior Member level 2
Hello,
I'm using the Altium Designer 16 and i making a small board.
I have done with routing and i trying to check it through eurocircuits online pcb checker.
But unfortunately i found that some annular rings have different size from others.
Althrough, all vias are the same, same diameter and same hole size!
What may it could be?
I want annular ring to be not minimum that 0.125mm
On pcb checker some annular rings on inner layers detected with different sizes from other layers (my board is 4 layers)
