analogue clock using stepper motor
Wajiduddaim
Junior Member level 1
darbar-e-Sadria
I want to make a analogue clock with stepper motor
The angle movement of stepper motor is 1.8 degree.
So 360 / 1.8 = 200 steps ... Right?
now suppose time is 10:27:38
now if I move motor every second the MINUTE needle should move very slowly and continually and after 60 seconds it should pass one minute distance, for this case what Gare ratio i should use
and
for every second and minute what Gare ratio is suitable for hour needle.
I m using only 2 motors for minute and hour
many stepper drivers are able to use microstepping method. Thus you get much better resolution than 200 steps per rev.
and
My hour needle takes 12 hours for one revolution.
my minutes needle takes 1 hour for one revolution = 60 minutes
me second needle takes 1 minute per revolution.
do you need more hints for gear ratio? ;-)
Klaus
