Analog voltage control by RS485
duglus
Newbie level 1
Newbie level 1
Sangli
Hi everyone,
I have done my 485 communication in both ASCII & RTU mode. So, I have no problem to read/write any data through modbus(i.e. char, short, long & float).
But now I want to operate analog voltage i.e 0 to 10 V DC through RS485 communication.
So please suggest me details of any idea or circuitry.
\][/quote]
Seems like you want a serial DAC; I bet there are some,
and you might like a "2 wire" interface (clockless / clock
recovery from the data stream). The DAC would probably
have a buffer amp for voltage & current-drive.
I use the Adam modules by Advantech. They have their own RS485 protocol and some of them also work on Modbus.
https://www.advantech.com/products/Analog-I-O-Modules/sub_GF-5VTD.aspx
In particular I have used the ADAM-4024 4 channel D/A with Modbus.
If you want more options just google "Modbus D/A"
For what it is worth, I wrote a series of 2 articles entitled "Generic Modbus Simulator" that appeared in issues 200 and 201 (March/April 2007) of Circuit Cellar. In it, the simulator communicated with several ADAM modules.
If you are interested in creating your own D/A, you may be interested in a follow up article "Create A Modbus Slave" that appeared in issue 216 (July 2008) of Circuit Cellar.
-Aubrey
P.S. Circuit Cellar's business model is to charge a nominal amount to download the articles.
Hi duglus,
I think its a job of 2x SO8 chips; a small PIC + a Serial DAC with voltage output...
K.,
