Jester
Full Member level 6
The circuit below is a squelch circuit, the analog switch is open when there is no audio and closed otherwise. The circuit works except for the nasty little spike that occurs when the switch is closed. I measured the voltage at LOUT with the switch open and it's close to ground (< 2mV). Not shown on diagram there is a weak pull down 100k at the o/p of the analog switch
It's not obvious to me what's causing the glitch.
Any ideas as to the cause and possible remedy?
