ericmar
Full Member level 5
Dear all experts,
I need some helps here. I am having this offset problem which causes me getting an incorrect output. I have an analog signal which comes to my circuit and go through an isolcation path before feeding into an ADC and this analog signal drops after the opto-coupler.
The analog signal is first being passed to an op-amp, AD820, then only an opto-coupler, IL300F. After the opto-coupler, the signal passes through another op-amp, AD8601, before it was fed into the ADC, ADS7816. The voltage at each point with reference to each side's ground is as the following:
At pin 3 of AD820, V = 1.933V
At pin 6 of AD820, V = 1.752V
At pin 5 of IL300F, V = 1.818V
At pin 1 of AD8601, V = 1.826V
May I know wat is causing this offset? How can I solve this problem?
Thank you very much for those who try to help me in advance.
Best regards,
Eric Mar
Best regards,
Eric Mar
