sudeeps
Newbie level 5
Hello friends,
I have certain questions which I'm trying to find answers to , please help me with these.
Hoping for help from the experts.
Thanks
- If we have two routes, one needs to carry voltage and one needs to carry current, what techniques to be used for each of these cases in layout ? why?
- If the drain of a transistor connects to pad, what are the special guidelines for the transistor? double guard ring etc ?
- Why double guard ring is needed ? How do you decide it's order ( P first ,then N or opposite ?)?
- Why we use VIA array? Why not single large VIA in place of several via's?
- Which type of diode is used to prevent antenna violation and how it works?
- Why thin metal are in lower position and thick metals are at upper position in a defined Stack?
- Why layout should be on grid? What's is the issue with off-grid errors ?
Thanks
