okguy
Full Member level 6
So many people in that forum are interrested in tanner or calibre ...
So many companies have shek|ist ...
Let' share them ...
Let's try to do the impossible exhaustive one, post your cheks ...
Analog layout shek|ist
Top level sheks :
Die size versus package
Bonding diagram pin order
Bonding diagram XY coordinates
All DRC/LVS log files stored in a database
All LVS warning explained and documented
Device part name and version in top metal
No active devices in chip corners
If multi-supplies, ESD protection between VSS supplies
Shielding on critical nets : Nwell and top metal
Supplies star routed
Cell level sheks :
Supply width
Transistor matching and dummies:
- same shape
- same orientation
- cross coupling
- same surrounding
Resistors matching and dummies:
- same shape
- same orientation
- cross coupling
- same surrounding
Check parasitic capacitances for high speed and switched-cap designs
Antenna diodes on input gates
Nice shield for critical cells
Test probe opening on critical nodes
OkGuy ?
Let' share them ...
Top level sheks :
Cell level sheks :
Supply width
- same shape
- same orientation
- cross coupling
- same surrounding
- same shape
- same orientation
- cross coupling
- same surrounding
OkGuy ?
