for analog design the tool below is better, under window system
1. schematic capture: workview
2. simulation : Hspice
3. layout : L EDIT
4. DRC/LVS: sorry i don't know
3. layout : L EDIT
workview is old tool , you only find wv "7.5"
ECS have windows/linux version , and hieary_check is ok
viewdraw is bad for check netlist , even some "cmos node float"
you will find generate netlist is "succesful" --> you must check netlist detail
1. schematic : cohesion ECS6 > workview viewdraw
2. sim : hspice or hsim or adit (aditspice have windows version)
3. layout : Ledit > mychip
4. DRC/LVS : ledit lvs or mychip lvs , but you need write command file
why not use linux, it is more statle than windows.
you can install a virtual maching software on windows so that you can switch between linux and windows easily
Added after 4 minutes:
cretu said:
hi all
Do you know where to get h§pice for windows? And some tech files?
Search in the other forum, such as software upload/download, EDA books / doc upload/download.
You are in the best EDA forum now, there are countless good resource hare, software, books, papers....
Dont always depend on the others, just search is yourself , just do it.
I've read the posts in this thread. However, 5 years passed from since last post, and I just would like to learn which tools are available currently on complete analog design flow, apart from Tanner's "Hiper" platform?
