analog feedback temprature regulator question
yefj
Advanced Member level 5
Hello, I am looking for a differential feedback temprature regulator project which explains the theory best it could and give practical example in simulation.
I am looking to design a very precise temprature regultor up to 1Kelvin.
Is there some material of a project I could try to learn it?
Thanks.
Temperature control plants can be quite different, I doubt there's a specific theory, just basic control engineering.
Important parameters are heater time constant, power supply and power control method, disturbance values. Depending on their relation, 1 K temperature accuracy can be very easy or demanding.
There is no universal solution.
Heat can be internal from pulsed power of the device and made be added or subracted with conductive sink/sources, convection and forced air. The solution requires a very good model of the problem and disturbances.
For SC-cut Xtals in OCXO ovens, they used double ovens with an elevated max temp. above ambient. That allows them to remain temperature stable better than 1e-11 in frequency.( if I recall)
For AT-cut Xtals in a can all you need is an 805 resistor and thermistor on a Kapton FPC inside styrafoam to ovenize it with a bridge (proportional) regulator to be less than 1 PPM in a few seconds.
For a YIG Oscillator being a 0.5 mm spherical crystal ball surrounded by an electromagnet in a metal nclosure, you need something very different.
Write your reply...
LaTeX Commands Quick-Menu:
