Analog division / One quadrant multiplier
juz_ad
Full Member level 2
Full Member level 2
I'm researching Division circuits to divide an input voltage of between approx. 0.1 to 10V by a reference voltage of approx. 0.8V. The planned circuit is part of an RMS to dBu converter.
There's a standard 4x op amp 4x transistor circuit in some of the major app notes and Walter Jungs op amp book but I've also been reading about quadrant multipliers.
Firstly - is it possible that division can be performed with a one quadrant multiplier?
Secondly - can anyone point me to some schematics for a one quadrant multiplier? Most of my books jump straight to four-quadrant,
I'm looking for transistor/op-amp circuits - not dedicated ICs please.
Thanks.
Why no ICs? Is this homework?
It's not homework.
I don't want to use ICs simply because I'd like to build it myself. I'm semi-familiar with some of the elements of the op-amp multiplier/divider circuits as I've done anti-log conversion before and this seems like not too far a jump from that.
I asked about quadrant multipliers because they appear to be based on current mirrors and I've done a little bit of work with transistor OTAs. A four quadrant multiplier is more complex than I want or need (I think…) - but I figured, if I could do division with a one-quadrant multiplier - then that might be a simpler circuit to get me started.
I can always build a more complex one later - or give up and use a dedicated IC!
Thanks.
Hi Juz_ad!
In the past, I was looking for a solution to an analog divider with single power supply, but only managed a multiplier circuit based on the MC1495. With the divider circuit I have not such success. I think that may be a base of your analog divider development.
Feri.
Sorry for my English.
If you need the complete PSpice file I will post it.
  • Test Points.pdf
  • Uout=F((Uin1 x Uin2) by 10).pdf
  • Possible Analog Divider.pdf
