Analog Design Question
Advanced Member level 3
Hi all,
I designed and simulated a flip-flop at transistor level and I wish determine set up and hold up times as well as the maximum clock frequency that can clock this flip-flop.
How can I do this ?
Any reply is welcommed.
Thanks in advance.
setup time:
1. set flip-flop to 0(1)
2. change data edge 0->1 (1->0) at T before clock edge
3. check flip-flop out
3.1 if D==1 (0) then T = T-dT
3.2 if D==0 (1) then T = T+dT
4. check accuracy of T, if not satisfactory go to 1
hold time:
2. change data edge 1->0 (0->1) at T after clock edge
We use bisection division method for determine setup und hold time.
Hi Kola,
What is this bisection method? Can you please explain?
any materials regarding the same would be very helpful.
Thanx
