[SOLVED] An urgent inquiry on ac analysis in CADENCE
nagamlan
Junior Member level 3
Hi...
Can any one kindly tell me how can I plot current vs frequency in ac analysis while using CADENCE. Thankss...
in ADE go to OUTPUTS -> TO BE PLOTTED -> SELECT ON SCHEMATIC, then click on the terminal to be plotted ( Red hollow square)
After running the simulation, you should get the current of that node vs frequency.
Thank you... Can you kindly tell me to plot input resistance vs frequency, should I use ac voltage or ac current source....
It doesn't matter. You can put in an AC voltage and measure the AC current, or put in an AC current and measure the AC voltage.
