an issue about Directivity
microantenna
Junior Member level 1
this shows the relationship between gain and A,my antenna frequency is 15.6GHz,A=35,4*pi*35/(300/15.6)^2=1.22,convert it to db is a very small value,can anyone tell me how to deal with it,or how to assess the gain of an antenna using its area
--- Updated ---
The effective antenna aperture Aeff in your equation is not identical to the area of your patch antenna. That only works for horn antennas and similar aperture antennas.
I would not even try to estimate Aeff, and simply simulate gain.
That said, your model looks strange. The patch has a small microstrip notch for microstrip feed that you have not used, and it seems that you try a probe feed instead. From your screenshot it is not clear if that is modelled properly, with only the center conductor passing through the substrate and touching the pad.
I recommend to look again at tutorials on patch antenna modelling.
LaTeX Commands Quick-Menu:
