An FM Modulator/Demodulator using fpga
eelinker
Full Member level 5
Full Member level 5
PERSIA
fm modulation fpga
Hi
Do you have any idea about this title?
The modulation may be fsk or Xpsk!
fpga fm
hey I'm workin on a simular topic. I hav to implement an Am mod/demo on fpga, but now I'm try learn vhdl language and quick start tutorial on ISe 8.1. I'm just begin my work.
MOC.......................thanx
    eelinker
fm fpga
hi
for Fm modulation / demodulation you need to implement PLL in fpga first this can be done using spice.
for the coding Verilog will be good.
    eelinker
modulateur fm sur fpga
don't u think an FPGA would be costlier for this.
check out the XR 2206 it has pretty simple interface circuitry.
    eelinker
fm modulation using fpga
i am also doing a similar topic... I have implemented FSK and PSK using DDS... got the idea from here:
https://instruct1.cit.cornell.edu/courses/ece576/DE2/
it is in section six... although the project is FM modulation, it is easy to convert or revise it to FSK...
But I am also trying to implement it using PLLs especially the demodulator part... If you have any idea how, please share your insights. thanks
