an error about check_deisgn command in synthesis process.
quan228228
Full Member level 4
Full Member level 4
the error infor is like below, please instruct me, thanks!
Warning: Parameter mismatch in linking reference 'non_recursive' by name.
Can't find design. (LINK-18)
Information: Building the design 'non_recursive' instantiated from design 'comb_0' with
the parameters "1". (HDL-193)
Warning: Can't find the design 'non_recursive'
in the library 'WORK'. (LBR-1)
Error: 'non_recursive' was not identified as a synthetic library module
and could not be successfully elaborated from design library 'WORK'. (LINK-10)
In design, i instantiate the module "non_recursive" four times like below.
non_recursive #(1) nr1(
.clk (clk),
.en (en_div2),
.rst_ (rst_),
.din (pdm),
.dout (nr1do)
non_recursive #(5) nr2(
.clk (clk),
.en (en_div2_2),
.rst_ (rst_),
.din (nr1do),
.dout (nr2do)
non_recursive #(9) nr3(
.clk (clk),
.en (en_div2_2_2),
.rst_ (rst_),
.din (nr2do),
.dout (nr3do)
non_recursive #(13) nr4(
.clk (clk),
.en (en_div2_2_2_2),
.rst_ (rst_),
.din (nr3do),
.dout (nr4do)
Is the problem related with the coding style or ...?
David
Re: an error about check_deisgn command in synthesis process
cut+paste code for module non_recursive as well
hi, quan228228
Maybe to set this variable "hdlin_auto_save_templates"
Sincerely,
Jarod
    quan228228
check whether u have given the command before compile option wherin u get the report of only the analyzed part..
if its after compile it has to be resolved.
jarodz said:
hi, quan228228
Sincerely,
Jarod
Thanks. you are right. I set this variable before reading/analying this module, the synthesis is done.
David
