omerysmi
Member level 5
- Joined
- Oct 10, 2014
- Messages
- 91
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 1,128
Hi, I think it's called a boost converter. Maybe in conjunction with a PWM IC/subcircuit could work.
Does the motor draw more current than the Arduino can provide? - Might be an idea to check that aspect; it may be necessary to use an external (12V) supply to handle the motor current.
Besides which, possibly a suitable interface to not damage anything when the motor turns off.
What max motor current?
Do you want to control motor speed?
Or switch it ON/OFF?
Klaus
But you still do not tell us the maximum current (the stalled current) of the motors so we do not know if a ULN2003A will melt.The problem is that i use something like 4 or 5 motors so i think that IC component is better(ULN 2003A etc..)
As i told you before i can't use in a power supply, the arduino connected to usb..You simply use a 14V power supply for the ULN2003A to drive 12V motors that have a maximum stalled current of 500mA.
It sounds like you want the Arduino to somehow generate 12V at the high current. Impossible. If the maximum output of an Arduino is 25mA at 4V then its output power is 25mA x 4V= 0.1W.
If you convert the 4V to 12V then the 12V has less than 0.1W (inefficiency of maybe 80%) so 0.08W at 12V allows a maximum output current of only 0.08W/12V= 6.7mA which will not run a motor.
Ok only one more question please, i want to use ic called LT1073-12Hi,
i can´t find the word "USB" in this thread before.
You still don´t specify current.
In post#2 d123 recommended a boost converter. Isn´t this a solution for your problem?
What do you expect? What help do you need?
Klaus
Someone already recommended that type solution. Apparently you did not understand what a boost switching power supply is. So best to look for something easier to understand: DC to DC converter power supplies.Ok only one more question please, i want to use ic called LT1073-12
This is maybe 1000 possible choices:
https://www.digikey.com/product-sea.../dc-dc-converters/590047?k=dc to dc converter
Does it is ok to connect the vcc(5v) of my arduino directly to the input pin of the LT1073-12 or should i make pwm signal
in post 2 someone reminded something about pwm and 555 ic.Hi,
I can't figure out why PWM? Where did you read about PWM?
No pwm at all.
It says 5Vin..
Klaus
