Amplifier with supply voltages of 0 and 5 volts.
aviaden
Newbie level 6
Newbie level 6
Israel
I'm trying to build a amplifier for a small signal, aound 2.5 volts.
Im using the AD8001 op amp. the signal is about 1 MHz, and of a few mvolts so i need a gain of about 40 db.
I've buid the circuits a described at the attached file.
First i used -5 and 5 volts as supply voltages for a signal around 0 DC. The circuit worked well.
But in my application i can't use -5 as supply voltage. so i've elevated the small signal to a DC of 2.5 volts, and used 0 and 5 as supply voltages. but i didn't get good results (No gain). I also tried to elevate the signal to 5 V DC and use 0 and 10 as supplies, but with no sucsses.
Please have a look at word file to see pspice simulations.
I will appreciate any help or ideas.
Thanks, Aviad.
Hi aviaden,
you should use a capacitor in series with the 390 ohms.
Thus, you have for dc 100% feedback (dc gain of unity). Thus, the input bias of 2.5 volts is transferred also to the output. Then, notice the highpass characteristic of your circuit.
    aviaden
Thanks, it really solved the problem.
Aviad.
