Amplifier 12 Mhz , Urgent !
truebs
Full Member level 5
Full Member level 5
Asia
Hello Friends !
I am urgently in need of some reference or circuit diagrams of an amplifier that can amplify my 12Mhz 200mV(crystal oscillator)
Signal to 12Mhz and around 2V (as high as possible ).
which amplifier should i look for ?
Please help !
Thanks !
Maybe this helpful
mike
www.ezpcb.com
Oops !! I forgot to mention mines is a sinosoidal oscillator , i guess above circuit would work with only square wave ?!!!
Please reply ! Thanks !
The easiest way will be to use an opamp.
You can select one from Linear Technology LT1357 - LT1365 ...
or similar from other manufacturers ..
it works with sine wave. the first gate amplifier the wave, the second shaping it into square wave.
Added after 4 minutes:
h**p://www.datasheetarchive.com/datasheet/pdf/2527.html
Of course that's better. AD8051 etc is also working, but the price....
