AMD29F010 Flash is Nand or NOR
vijaytanjore
Member level 1
Member level 1
India
Please let me know AMD 29f010 flash memory belongs to Nand or NOR type
it's a NOR flash type
What is your reference M!K?
Amr Ali
Does this data sheet show the flash type?
Amr
no, but the interface
Not necessarily. JEDEC just specifies footprint, command set, etc.
But I mean the kind to access the memory contents. For read access this is the same as for SRAM. You simply specify an address at the address bus and the corresponding contents is provided at the databus.
So this flash can be connected to an microcontroller and the program runs directly from it. This is not possible with a NAND flash.
You are right. NOR flash is a XIP. But this is not assures it is really a NOR flash.
Amr
