[SOLVED] ALU Design on VIVADO for RISCV Architecture
michaelScott
Junior Member level 2
Hello people,
I am designing a RISCV ALU on VIVADO and i want all the instructions as sub-blocks as seen the code below(carry-lookahead adder/subtractor). I want only one carry-lookahead adder/subtractor in the ALU for the different instructions like add and subtract. Can you help me about that. In the output i see only high impedance.
`timescale 1ns / 1ps
module alu(
    input [31:0] X, //instruction input
    input [31:0] A, //data input
    input [31:0] B, //data input
    output reg [31:0] C
wire [31:0] add, sum;
wire C5;
carry_lookahead M0(A, B, 0, add, C5);
carry_lookahead M1(A, B, 1, sum, C5);
///////////////////////// R TYPE /////////////////////////
wire [6:0] funct7;
//reg [4:0] rs2;  //address
//reg [4:0] rs1;  //address
wire [2:0] funct3;
//reg [4:0] rd;  //address
wire [6:0] opcode;
///////////////////////// I TYPE /////////////////////////
wire [11:0] imm;
//reg [4:0] rs1; //register adress
//wire [2:0] funct3;
//reg [4:0] rd;  //register adress
//wire [6:0] opcode;
wire [31:0] imm_i;
assign imm_i = {{20{imm[11]}}, imm[11:0]};
wire [31:0] sum_imm;
carry_lookahead M2(A, imm_i, 0, sum_imm, C5);
assign funct7 = X[31:25];
//assign rs2 = X[24:20];
//assign rs1 = X[19:15];
assign funct3 = X[14:12];
//assign rd = X[11:7];
assign opcode = X[6:0];
assign imm = X[31:20];
always @(funct7[5], funct3, opcode, A, B)
begin
C = 0;
case (opcode)
    7'b0110011: case(funct3)
        3'b000: case(funct7[5])
            1'b0: C = add;  //add
            1'b1: C = sum;  //sum
            endcase
        3'b001: C = A << B;  //sll
        3'b010: C = (A < B) ? 1'b1 : 1'b0;  //slt(signed)
        3'b011: C = (A < B) ? 1'b1 : 1'b0;  //sltu(unsigned)
        3'b100: C = A ^ B;    //xor
        3'b110: C = A | B;    //or
        3'b111: C = A & B;    //and
        endcase
    7'b0010011: case(funct3)
        3'b000: C = sum_imm;    //addi
        3'b010: C = (A < imm_i) ? 1'b1 : 1'b0;  //slti(signed)
        3'b011: C = (A < imm_i) ? 1'b1 : 1'b0;  //sltiu(signed)
        3'b100: C = A ^ imm_i;//xori
        3'b110: C = A | imm_i;//ori
        3'b111: C = A & imm_i;//andi
        endcase
endcase
end
endmodule
--- Updated ---
I improved the design as seen below but i get error about the out signal.
What do i do wrong.
thanks in advance
module alu(
    output reg [31:0] C
reg [31:0] in1, in2, out;
reg M, C5;
carry_lookahead M0(in1, in2, M, out, C5);
wire [6:0] funct7;
wire [2:0] funct3;
wire [6:0] opcode;
wire [11:0] imm;
wire [31:0] imm_i;
always @(funct7[5], funct3, opcode)
begin
C = 0;
case (opcode)
            1'b0: begin
                    in1 = A;
                    in2 = B;
                    M = 0;
                    out = C;  //add
                    end
            1'b1: begin
                    in1 = A;
                    in2 = B;
                    M = 1;
                    out = C;  //sum
                    end
            endcase
        endcase
        3'b000: begin
                in1 = A;
                in2 = imm_i;
                M = 0;
                out = C;  //addi
                end
        endcase
endcase
end
endmodule
