sakibnaz
Full Member level 3
Hi there.
I have a ques on Altium Via's (Buried and Blind).
Say my Board is 4 Layer ... where I want to route a trace from Bottom layer to Signal layer 1. Now in Via Stetting will I use:
Start layer: Bottom
End Layer: Signal Layer 1
Or,
Start layer: Signal Layer 1
End Layer: Bottom
Or, both are same thing?
Similarly for Trace between Signal layer 1 and 2:
End Layer: Signal Layer 2
Or
Start layer: Signal Layer 2
Form routing point, I can see both via settings can lay the Tarce ... but just wanted to be sure if there is any fabrication issue.
Please advise.
Thanks in advance.
Regards.
Start layer: Bottom
Or,
End Layer: Bottom
Or
Please advise.
Thanks in advance.
Regards.
