altium: unique ID problem
ahycka
Newbie level 3
Newbie level 3
Hi
I have a problem with unique ID and I don't know why.
If I compile the project, I dont have any message about uniqueID in schematics, but, when I try to print the project (schematic and pcb) I have some uniqueID warnings like this:
[Warning] blablabla.PcbDoc Compiler Unique Identifiers Errors: VTUCFRWP found at Unknown and Unknown
I check component by component and in schematic reference information field appears:
\KPLKCUDL\NGBJEDDM\RVTUDSNW\VTUCFRWP
\KPLKCUDL\NGBJEDDM\EEOMMGGR\VTUCFRWP
\KPLKCUDL\NGBJEDDM\QJEQFBWY\VTUCFRWP
so, the unique ID is correct in schematic. I check .Annotation file, and the unique ID is right too
How can I solve these warnings?
Regards
Did you check the component links?
Udhay
If still the problem exist, you may need to do it manually. Can you give us the screenshot of the error message?
Udhay
Sure
Here it is the error message and the error detail. AltiumWarning.pngaltiumWarningDetail.png
I tried to generate a new project and adding all the files, but i had still the same problem.
I tried to add a empty pcbdoc and copy/paste the whole pcb into the new file, but i had the same problem...
Today I'll try to delete the .sch file, but i dont think it will work.
