krivassama
Newbie level 3
I'm trying to translate my Altium design to Cadence. The schematics translation worked fine, but I'm having problem with the PCB. Looking in the web, the procedure I found was to first export a .pcb file (Protel 2.8 ASCII) and then import in Layout+ a max file. But when I try to import, instead the max file I just get a log file, where it says an error occurred (Error code 5226.074).
This is the exactly same problem related in this thread (but since it's very old I posting a new one):
https://www.edaboard.com/threads/112154/
But no reply. In another related thread, also no solution:
https://www.edaboard.com/threads/268171/
Does anyone knows a fix to this? Or another way to do this translation?
Thank you,
Vinícius
Thank you,
Vinícius
