Altium Repeated Buses
cciarleg
Junior Member level 3
I'm getting a "duplicate net names bus slice" error. I would like to use a sheet symbol multiple times, something like the attached. It is, essentially, a repeat (which Altium recognizes and creates the correct channel repeats). How can I name these buses (there are 6 sheet symbols like this) such that the error is resolved? (Either using this method or using repeat)
Thanks.
Thanks.
Because that's what it is. You need to name them to the correct sheet where you got buffer.shcdoc to say if your second sheet is buffer2.schdoc in the sheet symbol. this may cure your error plus there is nothing connected to the out on them
