EEJones
Newbie level 2
Is it possible to take one or more of the "Document Options>Parameters" and put it into the "Tools>Annotation>Number Schematic Sheets" dialog box?
This would allow the document parameter to be set for each sheet in one place instead of opening the document parameter for each sheet. The way I understand Altium's document parameters doesn't make sense. If I have to open the parameter for each sheet I might as well just use place text string and edit it.
Thanks for your Time
